jrivera
Nov 20, 2017Initiate
Mobile devices slow on Nighthawk R7900
I noticed all of my mobile devices have slow internet speeds.. Both up and download speeds. However my MacBook and Dell XPS both reach download speeds above 110Mbps. I even tried testing my download ...
- Nov 30, 2017
Thanks for replying and your suggestion. I attempted to reset my router again for the second time and it seemed to have helped my issue. For some odd reason I didnt see a change and encountered the same behavior after the first reset but after the second the speed was increased and is operating as it should.
JamesGL
Nov 23, 2017NETGEAR Employee Retired
Hi jrivera,
Try changing the channel of your wireless network.
Disable QoS.
- JamesGLNov 27, 2017NETGEAR Employee Retired
Hi jrivera,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- jriveraNov 30, 2017Initiate
