YakFlyer
Dec 09, 2021Follower
Mobile Phone Hotspot - Netgear Nighthawk R7800 AC2600
Hi Trying to use my mobile personal hotspot data using the R7800 Nighthawk, any advice would be very welcomed. Thank you. YakFlyer
Dec 09, 2021Guru - Experienced User
What mobile phone hotspot do you have?
Have you check with the mobile provider on if the hotspot supports a direct connection?
What error are you getting?
Is the R7800 in AP mode or the hotspot in passthrough mode?
