phinelli
Nov 12, 2020Aspirant
MoCA adapters?
Does Netgear have MoCA adapters that are compatible with CenturyLink C4000 router?
Nov 12, 2020Guru - Experienced User
I'm not aware of any newer version for moca adapters for netgear.
phinelli
Nov 13, 2020Aspirant
I would like to use existing (typical in wall ) coaxial cable, with MoCA adapters, and then to connect with ethernet "ends" into Centurylink C4000XG and TV/Roku on other end.
Question: does Netgear sell adapters, connectors for this purpose?
- antinodeNov 13, 2020Guru
> I would like to use existing (typical in wall ) coaxial cable, [...]
Ok.
All my search found was the old/obsolete (MoCA 1.1) model cited
above. A quick Web search for terms like, say, "MoCA adapter" should
find newer/better stuff from other vendors. (And, from Netgear, if they
still offered any.)
