Daniel24
Oct 10, 2021Aspirant
Model : EX7300v2
Bonjour, je possède un répéteur WIFI EX7300v2. Il fonctionnait bien jusqu’à hier, après le raccordement de la fibre. Dès qu’il est branché, on peut directement (sans temps de latence) observer q...
Oct 10, 2021Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFI Extenders and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Daniel24
Hello, I have a WIFI repeater EX7300v2.
It was working well until yesterday, after the fiber connection.
As soon as it is connected, we can directly (without latency) observe this:
Only the WPS button is green.
The power button is orange
The two buttons " Router Link " and " Client link " are orange
And the two direction buttons are blue.
None of the lights are blinking.
I tried the reset for 30 seconds and more, but it does not work.
Can you help me? Thanks in advance.
- FURRYe38Oct 10, 2021Guru - Experienced User
Has the extender been unplugged from the wall socket for 30 seconds then back IN?
Can you check the power adapters voltage and amps to be sure the adapter is working ok?
Afer pressing the reset button for 10 seconds then release, can you not see the default SSID wifi name using the setup app on a moble device?
- Daniel24Oct 10, 2021AspirantYeah, actually I have tried all this.
Plug and unplug it.
Try the reset for 10 seconds (nothing is happening)
The only thing I can’t do, because I don’t know how it works, is to check the voltage.- FURRYe38Oct 10, 2021Guru - Experienced User
Need a volt meter. Might see if you have a friend or family member or a electronics repair shop facility around in town that could help check that.
Seems like either the power supply could be bad or the EX itself is bad. How long have you had the EX for?
