Jameslegend
Apr 13, 2024Follower
Model # R6900 I am having trouble logging into the app
I got this model today and every time I try and login to the app it says troubling logon try rebooting device and I’m wandering if the this WiFi router is only compatible with netgear internet or if I...
michaelkenward
Apr 14, 2024Guru - Experienced User
Is this a second hand router? Even the V2 hardware variant dates back to 2017. V1 is even older.
If it is second hand, be sure to reset the thing before you try using it.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
That will wipe any previous user settings.
