Cap118
Dec 23, 2020Follower
Model C3700v2. I need to change my password
I need to change my password on my router. I went on routerlogin.net and entered admin and password but it didn't work. Any ideas?
Dec 23, 2020Guru - Experienced User
to log into the router the defautls are admin/password
If those don't work, they were probably changed. You can try using the password recovery option but if you didn't set it up or don't know the answers, then you'd need to factory reset to get back tot he defaults.
Not sure if the C3700 has password recovery but worth a shot.
