_MGD_
Jan 09, 2022Aspirant
Model Id: R6700v3 Network Speed issues
This past Summer, I upgraded my Verizon FIOS to be provisioned at 400 MBPS up and down and installed a Netgear Nighthawk instead of a Verizon router At that time, I confirmed that speed (400 over 40...
michaelkenward
Jan 10, 2022Guru - Experienced User
_MGD_ wrote:
One of their requests was that I should revert the Netgear Nighthawk to factory settings
1. Is there any merit to their suggestion that i reset the router to factory?
Yes. Your network has changed and the router may have some settings remembered from the previous connection.
When you change your Internet service – hardware, supplier or speeds – you have a different network. So it helps to start from scratch. Tell all the devices on the network to forget any settings carried over from your previous network. An alternative is to tell the router to run the Internet setup wizard. It will then go out an negotiate the appropriate setting for your "new" connection.
- _MGD_Jan 10, 2022Aspirant
I tried the suggestion: Network Wizard
Still getting only 200 MBPS speedTest from Verizon
Other speed tests showing about 250 MBPC
In other words, no change
a screenshot of Windows 10 Task Manager seems to show FIOS is capped at 200 MBPS
Any other suggestions?
- michaelkenwardJan 10, 2022Guru - Experienced User
I don't know how to interpret that image.
Looks like something in Windows rather than the router.
