pressgang's avatar
pressgang
Model numbers
Please let me know if the model numbers are different in EU countries? For instance I am looking for the R7000 and other Nighthawk routers here in Spain. Regards Barry
  • plemans's avatar
    Nov 01, 2022
    michaelkenward is correct. Its the end of the model number thats region specific. The first part of the model should be the same.
    But if I was looking for a router, i'd recommend something a little newer. The R7000 isn't a bad router but it was released in 2013. Something from the newer RAX line might be a better idea (and potentially cheaper)
