Pmuser
Feb 28, 2024Aspirant
Model R 7000 Suddenly no longer works without notice
Yesterday my Model R7000 AC1900 unit stopped working. I have been using it to extend my home wi-fi. I called Netgear and was told that I now have to buy a service plan for this unit. I was told that ...
- Feb 29, 2024
Did you try to manually update the router yet?
Feb 28, 2024Guru - Experienced User
What do you mean by no longer works?
What's happening?
Any top LED indications?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Pmuser
I called Netgear customer service yesterday and they told me that the router/extender no longer works and I have to buy a service plan that costs more than the router did to begin with. I won’t be buying anything from Netgear again.
