Pmuser
Feb 28, 2024Aspirant
Model R 7000 Suddenly no longer works without notice
Yesterday my Model R7000 AC1900 unit stopped working. I have been using it to extend my home wi-fi. I called Netgear and was told that I now have to buy a service plan for this unit. I was told that ...
- Feb 29, 2024
Did you try to manually update the router yet?
Feb 28, 2024Guru - Experienced User
What do you mean by no longer works?
What's happening?
Any top LED indications?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Pmuser
I tried the majority of your suggestions and appreciate the input. When I called Netgear customer service, they pulled up my information. They knew exactly when I purchased the product and they also could tell which FW updates had been done. They told me the router was only good for three years and that additional FW updates can’t be done without the purchase of a new service agreement. They gave me the options of a three year or five year plan. I am not going to spend more for a service agreement than I did for the router. They also told me that the purchase of a new product from Netgear only comes with 30 days of service coverage and every new customer has to buy a service agreement to cover beyond the 30 days.
- FURRYe38Feb 28, 2024Guru - Experienced User
Ya someone at support is trying for more money when there isn't a need. Firmware updates can and are supported by manually updating the router by you with a ethernet connected PC and web browser. It's not something NG can't prevent if you don't pay for a support fee.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
FW files can be found here:
Or here:
https://www.netgear.com/support/
- PmuserFeb 29, 2024Aspirant
Thank you. This is very helpful. Too bad their customer support folks aren't as helpful as you.
- michaelkenwardFeb 29, 2024Guru - Experienced User
I have no idea who you talked to, but that statement makes me suspicious.
Why? Because it is just plain wrong.
Here's what the Netgear site says:
Complimentary Support
NETGEAR provides complimentary technical support for NETGEAR products for 90 days from the original date of purchase.- PmuserFeb 29, 2024Aspirant
Thank you for your help. I called Netgear again yesterday. I am going to throw the router away and research other options if I ever need an extender again. Planning to switch internet providers soon and their equipment should cover the entire house.
- FURRYe38Feb 29, 2024Guru - Experienced User
