loffstein
Feb 16, 2021Aspirant
Model R6220
Model R6220 In the past I had two network lines coming into my router and recently one of them dissappeared. Does anyone know of how I can reestablish the second one?
loffstein
Feb 17, 2021Aspirant
Thank you for your reply. I live in a building that supplies two lines of different speeds and up until recently I was getting both through my router and now I am only getting one of the two. I've restarted my router and PC several times and that has not solved the problem.
antinode
Feb 17, 2021Guru
> [...] I live in a building that supplies two lines of different
> speeds [...]
"lines"? Ethernet, or what? From where?
> [...] up until recently I was getting both through my router [...]
I don't see how. Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual (at
least). Read. Can you find any place where it describes connecting
multiple "lines" that way?
What, exactly, did you connect to what, exactly? (Hint: If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.)
> [...] now I am only getting one of the two.
"getting"? Not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
When you were "getting" both "lines", how, exactly, did you choose
between them?
> Not sure what you mean.
I doubt that anyone here knows what you mean. Or believes that you
could do what you seem to claim.
