msmith4501
Feb 03, 2021Aspirant
Model R6700v3 My weather station (LaCrosse Model C8300) will only connect using 2.4 GHz
Model R6700v3... My weather station (LaCrosse Model C8300) will only connect using 2.4 GHz. It was connected to the router, but I had to change the battery in the weather station and then it would no...
BarryD0706
Feb 05, 2021Aspirant
One more piece of information. (I just tried it again. SSID broadcast is on (so WPS would work) and Access Control is disabled.)
There is absolutely nothing shown in the Router logs during the "Easy Connect" attempt. All logging options are selected. I would certainly expect to see somethiing in the logs wouldn't I?
DarrenM
Feb 09, 2021Sr. NETGEAR Moderator
Have you tried to change the 2.4 ghz channel?
DarrenM
- msmith4501Feb 09, 2021Aspirant
There was no way that I could find to do this so I bought a different one...not Netgear. Thanks for trying to help!
