vinnyd51
Nov 19, 2021Tutor
Model R6700v3 router with internet connection issues
This router is in a 2nd home which we go to every couple of weeks. Each time we get to the home lately, we have no internet connection. The cable company says it's the router. If I reboot the router,...
Nov 19, 2021Guru - Experienced User
- vinnyd51Nov 19, 2021Tutor
I did manage to find the firmware version on my phone app. It is V1.0.4.106. However, when I try to check for updates, I get firmware check error.
- wcalifasNov 19, 2021Prodigy
There's newer firmware for your router I see1.0.4.120 available on the netgear website which you can apply to the router and see if that helps https://www.netgear.com/support/product/R6700v3.aspx#download
Thanks for the reply. I will certainly try that. However, as I mentioned in an earlier post, when I try to check for an update to my firmware from my phone app, I get a firmware check error. Can this update be done manually somehow?
- FURRYe38Nov 20, 2021Guru - Experienced User
