rnthom54's avatar
rnthom54
Model R7000 - The router just doesn't work after a factory reset to clear my password
Well, after many re-sets and such the router will not produce a wifi signal. I've completely unplugged everything at least 3 times and started fresh just like it came out of the box and it still won'...
  • Kitsap's avatar
    Kitsap
    May 01, 2021
    Some information that would be helpful is the brand name and specific model number of your modem.  If it is just a modem, not a problem.  If it is a combination modem and router there can be issues.
    The default Wi-Fi password is printed on the nameplate on the router.  It is case sensitive.  The Wi-Fi SSID and password are part of the firmware default settings that are put in place after a reset.
    Connecting to the Wi-Fi from a phone should work fine.  Your understanding about configuring a router via a phone app is completely wrong.  I repeat, attempting to configure the router via a phone is a fools errand.  Contrary to your understanding or any advertisements from a manufacturer, if all you have access to is a phone for configuration, you are stuck.
