Steveturner
Oct 26, 2016Aspirant
Model R7000 How can I turn on 5GHZ or how do I know if the 5GHZ is being used?
I want to make sure my laptop is using the 5ghz band. But I don't know how to tell the router to do that.
- Oct 26, 2016
You DO NOT tell the router to do that, you tell the Laptop what SSID to connect to. Obviously you do not set both SSID's to the name.
michaelkenward
Oct 27, 2016Guru - Experienced User
This came up here not long ago. On investigation, the owner of the laptop found that their PC did not actually support 5G.
Steveturner
Oct 27, 2016Aspirant
My Dell laptop does support 2.4 and 5GHZ and the router does too. I just wasn't sure how to tell if and when 5GHZ was being used.
