snmeddington's avatar
Nov 10, 2019
Model: R7900P, I cannot upgrade my macOS to Catalina (10.15.1)
R7900P Nighthawk X6S AC 3000.   I'm using macOS on a brand new iMac 27" and it is fully connected to the internet. The upgrade now button will just timeout and say that it lost connection with the ...
  • plemans's avatar
    Nov 12, 2019
    shouldn't even need to do that. Unplug from the back of the router and use that to direct connect. Download the file and then reinstall the router.
