SamJr's avatar
SamJr
Model R9000 - Netgear Genie Software
I need to reinstall netgear genie on a new computer and i did not receive a cd/dvd when i purchased my router.  Where can I get a copy of Netgear Genie?  It does not show up on any of the software do...
  • michaelkenward's avatar
    Dec 13, 2020
    SamJr wrote:
    Went to the recommended site however there is no place to download the Netgear Genie software.  All this link points to are apps to load on mobile devices.  I need to install the software on a PC.
    I don't know what you clicked, but it goes to the software here.
    https://www.netgear.co.uk/home/discover/apps/genie.aspx
    Scroll to the bottom.
    Look for the link:
    DOWNLOAD PC
