SamJr
Dec 12, 2020Aspirant
Model R9000 - Netgear Genie Software
I need to reinstall netgear genie on a new computer and i did not receive a cd/dvd when i purchased my router. Where can I get a copy of Netgear Genie? It does not show up on any of the software do...
- Dec 13, 2020
SamJr wrote:
Went to the recommended site however there is no place to download the Netgear Genie software. All this link points to are apps to load on mobile devices. I need to install the software on a PC.
I don't know what you clicked, but it goes to the software here.
https://www.netgear.co.uk/home/discover/apps/genie.aspx
Scroll to the bottom.
Look for the link:
SamJr
Dec 13, 2020Aspirant
michaelkenward
Dec 13, 2020Guru - Experienced User
Look for the link:
- SamJrDec 13, 2020Aspirant
Thanks, I clicked on the "Download PC" link at the bottom of your last post and it worked.
Sam
