Teenie
Jan 02, 2022Initiate
Model Rax35
To change my Wi-Fi password should I use Www.router login.net? I have a new cell and I opened the Nighthawk icon. Prompted me to log in. I wasn’t sure which password so I reset It. This got me into t...
- Jan 02, 2022
You can change it through the app or using the browser. Either method works.
You can always log into the router through the browser and check what the ssid/password is.
