Sufferingbearsf's avatar
Nov 30, 2021
Model WAC104 access point, can I connect direct to the cable modem that the head router uses
I have a Nighthawk connected to the cable modem.  I added a wired access point Model WAC104 and connected it by wire to the same cable modem.
Will that work OK?  The instructions say to connect the access point to the router and thent he router to the cable modem
Trying to maximize speed at the far side of the house
  • plemans's avatar
    If should work if you're hardwiring the access point into a router.
    What actual nighthawk is it?
    • Sufferingbearsf's avatar
      Sufferingbearsf
      I have the R8000P wired to the modem.  The access point is also hard wired to the modem.
      The person who installed the access point said that this will work, and it does work.  However the instructions say to wire the access point to the Nighthawk, and not the modem
      The access point speeds are not what I expected and so I wondered if wiring the access point to the modem, and not the Nighthawk is causing a problem?
      • FURRYe38's avatar
        If the WAC is connected to the modem then try connecting it to the NH router.
        What is the distance between the WAC and th NH router? 30 feet should be a good starting point.
        Be sure the channels on the WAC are far appart from what the router uses. Set the WAC for channel 1 and 36 while setting the router for 11 and 149.
