ljl2658
Jan 10, 2021Follower
Model WNR 1000V3 can't update firmware
I received an email that says "We've enhanced your products security. Please update to the latest firmware." When I try to do the update it says there are no updates for my product. My router shows...
michaelkenward
Jan 11, 2021Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual on updating the firmware.
Alternatively,try this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
The WNR1000v3 is now more than 10 years old. Firmware updates eventually come to an end.
