Lionhawk
Aug 16, 2021Star
Modem & Router with Xfinity issue Drop in speeds
Hello all, I am pretty much a novice when it comes to setup beyond the basic stuff. I have Xfinity 1200 mbps and using the below equipment: Modem: Netgear CM1150V Router: Netgear Nighthawk R70...
Aug 16, 2021Guru - Experienced User
What firmware is on the r7000p?
Try a factory reset and reinstall. during the install make sure to leave access control, qos, traffic monitoring, and parental controls all disabled.
- LionhawkAug 17, 2021Star
Thanks, I will attempt that....its been a while since I even touched it so I will have to read up on how to do the factory rest.
- plemansAug 17, 2021Guru - Experienced User
Pretty easy. push and hold reset for 7-15 seconds while powered on. Then reinstall it.
- LionhawkAug 18, 2021Star
Hello again and thanks for replying....does the reset have to happen in order to change those settings you listed?
ANd if so, once I begin the reset is there a disc that needs to installed or is it online or does it self setup?
I cant remember, and I didnt want to reset anything if I have a disc laying around somewhere that i need to dig up.
