Tiritibambix
Dec 26, 2021Tutor
Modem and router on the same network
Hello ! Sorry if this is a noobish question, but I'm just starting to learn about network and servers and I don't really know the terminology and terms to type in my search engine. Also, forgive...
- Dec 26, 2021
simple.
Put the R6120 in access point mode. that'll have it on the same subnet so all the devices can see each other.
Dec 26, 2021Guru - Experienced User
simple.
Tiritibambix
Dec 26, 2021Tutor
That worked ! Thank you very much.
However, now my router IP adress isn't displayed anymore in my modem's listed devices so I have to "guess" its adress to enter the setup page.
Also, One of my servers isn't listed either in my routers devices list. It has an IP, I can access it, but it is not displayed.
Would you know why this could happen ?
- plemansDec 27, 2021Guru - Experienced User
After changing the router over to ap mode, The devices connected to it might need to be rebooted to pull a new ip address that is in the same range as the primary router.
- TiritibambixDec 27, 2021Tutor
Again, thank you very much for your help
