Tiritibambix
Dec 26, 2021Tutor
Modem and router on the same network
Hello ! Sorry if this is a noobish question, but I'm just starting to learn about network and servers and I don't really know the terminology and terms to type in my search engine. Also, forgive...
- Dec 26, 2021
simple.
Put the R6120 in access point mode. that'll have it on the same subnet so all the devices can see each other.
Dec 27, 2021Guru - Experienced User
After changing the router over to ap mode, The devices connected to it might need to be rebooted to pull a new ip address that is in the same range as the primary router.
Tiritibambix
Dec 27, 2021Tutor
Again, thank you very much for your help
