rms0867
Dec 10, 2021Follower
Modem Recommendation
Hello: I am looking at the following modem CM2050V; however, do not see that it supports the dual frequency band. Specifically, looking for 2.4GHz frequency band to use with smart bulbs. Is there...
microchip8
Dec 10, 2021Master
Unfortunately, if I'm not mistaken, there's no NETGEAR gateway that offers DOCSIS 3.1 and a 2.4 GHz band. All seem to be 5 GHz only with 2.5 Gbps WAN ports
What you can do is get a modem-only device and hook up a router to it that provides 2.4/5 GHz bands
