rms0867
Dec 10, 2021Follower
Modem Recommendation
Hello: I am looking at the following modem CM2050V; however, do not see that it supports the dual frequency band. Specifically, looking for 2.4GHz frequency band to use with smart bulbs. Is there...
Dec 10, 2021Guru - Experienced User
The CM2050V is a modem only device. It doesn't have wifi or any routing capability.
If you purchase that modem, you'd need to add your own router to it.
