rms0867
Dec 10, 2021Follower
Modem Recommendation
Hello: I am looking at the following modem CM2050V; however, do not see that it supports the dual frequency band. Specifically, looking for 2.4GHz frequency band to use with smart bulbs. Is there...
Dec 10, 2021Guru - Experienced User
The CM2050V is a modem only device. It doesn't have wifi or any routing capability.
If you purchase that modem, you'd need to add your own router to it.
microchip8
Dec 10, 2021Master
From reading the OPs question, he's looking for Xfinity-certified devices. Are you guys sure that CAX80 & co support Xfinity?
- plemansDec 10, 2021Guru - Experienced UserYes. The cax is supported on Xfinity
- michaelkenwardDec 11, 2021Guru - Experienced User
plemans wrote:
Yes. The cax is supported on XfinityBut would you recommend a combined modem/router over a separate modem and router?
