AJGCOLO
May 02, 2021Aspirant
Modem wont send Internet to router
Have a CM1200 cable modem hooked to an Asus RT-N66R router. Have had this set up for some time. The other day the internet stopped working. Went through reseting both modem and router with no success...
May 03, 2021Guru - Experienced User
The CM1200 has 4x ethernet ports.
But through comcast, they only allow 1 device to be connected to it.
Both comcast and xfinity do a poor job of explaining the purpose of the 4x ports on the cm1200 (for business class setups or for the rare isp that supports mulitple public ip addresses)
so if you have more than 1 device connection try this.
disconnect all devices from cm1200.
power off the cm1200 and the router.
power the cm1200 back on and give it a couple minutes.
attach the router to port 1 on the cm1200 and boot up the router.
give it a couple minutes and then try setup.
Make sure to only have 1 device connected to the cm1200.
AJGCOLO
May 03, 2021Aspirant
I learned this when on first got the modem, as no one explained it to me at that time. When testing I only would have the router plugged in and into port 1. Any other ideas?
- plemansMay 03, 2021Guru - Experienced User
Try this. Factory reset both the modem and the router. Push and hold reset for 7-15 seconds while they're powered on.
then disconnect the coax from the cm1200 and disconnect everything from the router and the modem.
then leave them for 2 minutes.
Connect coax back to the cm1200
power it on and wait 2 minutes
connect a new ethernet (cat 5e or greater) to the router's wan port.
Then turn the router on. give it a couple minutes and then attempt setup.
