Daddysmell
Apr 15, 2018Guide
modem/router combo
I have spectrum internet with a LAN LINE and I want a one piece combo can anyone help me with the combo? I have 100mbps right now looking to upgrade to 400mbps in the near future or would it be bette...
- Apr 15, 2018
xnsys wrote:OK, then it looks as though the internet is provided by a "F" type connector, which is coaxal.
You would need to confirm, but this may suit your needs
http://www.netgear.com/home/products/networking/cable-modems-routers/C7800.aspx
While it probably would, Spectrum CAN get fussy when non-approved devices connect to them. First when you install it you'll need to call them to 'approve' the MAC address and make it useable. I've heard stories from others that they refused to do that as the device was NOT on the list of approved devices, others where the phone agent did it without question, and still others that it was connected at first and some time later disconnected from the network and they couldn't get it authorized again.
That is also a $400 modem from Amazon. Even if Spectrum charged $10/mo. for wireless that would take 40 months to recover the cost. Not a wise investment in my book...
xnsys
Apr 15, 2018Luminary
Daddysmell wrote:I have spectrum internet with a LAN LINE and I want a one piece combo can anyone help me with the combo? I have 100mbps right now looking to upgrade to 400mbps in the near future or would it be better to buy other router? Again Im looking at just having one piece combo. (I E) I have a LAN LINE
Where are you based? There are several ISP's called Spectrum Internet round the globe.
Daddysmell
Apr 15, 2018Guide
Buford, Georgia
- xnsysApr 15, 2018Luminary
So not UK Cardiff then lol
OK, so this is the ISP.
What is the physical connection that plugs into the router/modem?
- DaddysmellApr 15, 2018Guide
what do you mean?
I have cable modem and a nighthawk router.
I'm just looking for a combo, but I dont know the difference between a combo and a me having a modem and a router?
I'm a netgear person.
Is the connection a coxal one that comes into the modem?
