jmwells57's avatar
jmwells57
Follower
Jul 15, 2022
Modify settings?
My unit blocks sites that are associated with goods tracking links.  How can I modify the settings to allow tracking from UPS, USPS and FedEx?
Also, the system has been slowing down my internet service.
NightHawk Netgear 41 system.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    How do you know this is the router rather than something on whatever you are using to access these websites?
    Maybe you have some Internet security application that does not like them.
    Again, what tells you that?
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
    That will probably be the name of the wifi SSID. It is not a Netgear model number.
    Look at the label on the thing for the model number.
