ElSupremo
Mar 31, 2025Aspirant
More on "R7000P router will not reset
Hey guys, I've tried it all, at least all that I know. The title says it all
First of all, the router works fine, I think. It connects to the Internet. When I connect via LAN to my laptop- no problems. Good Internet, good speed.
The Wifi signals are there, but I forgot the passwords so I can't test them.
Sooo,,, I power on, let it boot up, hold down the reset button until the cows some home, no response, nada.
Soo... I power off, hold down the reset button, and power on. This time the router doesn't boot, it just cycles through some lights. I release the button after a ridiculous amount of time, then it boots back to the usual working state where it was before. This tells me that the reset button is probably functional, I mean it does do something.
30-30-30 reset- no joy.
I tried the TFTP procedure at various times during what passes for the boot up cycle (and yes, I've done this successfully on other Netgear routers so I know what I'm doing...)- but- at no time does the power light flash (so I assume I'm never in Recovery mode), and TFTP times out - "failed to connect"
The bare board is now out of the case- I tried ohming out the Reset button but did not get any response, i.e. no change in continuity between the pins. If the reset switch did nothing, I would suspect it was defective, but it does no "something" per the 5th paragraph. I was hoping tind something on the board, like a pin header (yes, there is one, labelled J251 with 4 pins and not otherwise labelled) with some functional label.
Interesting conundrum. Any ideas.
Does the ERASE button work with in the routers WEB page under Advanced tab/Admin/Backup?
30-30-30 reset should have cleared everything out. Surprised that didn't.
- ElSupremoAspirantRouter webpage not accessible, forgot password.
J251 header is a serial interface, probably 9600N81. Any info on pinout or commands?
