haberdasher_99
Apr 21, 2019Aspirant
most stable firmware for R8900?
Taking a poll of the most stable firmware. I had trouble with 5Ghz for the past week or so with V1.0.4.28. I downgraded to 26.
When I upgraded to 28 I did a factory reset and reapplied my confi...
- May 04, 2019
After a few weeks V1.0.4.26 has remained stable. Key is to factory reset after updating the firmware to V1.0.4.26, turn off MU-MIMO and Beamforming as has been recommended in other threads.
haberdasher_99
Apr 22, 2019Aspirant
Is Voxel open source so I can inspect it?
Kamoj
Apr 22, 2019Apprentice
Voxel publish his source code on Github:
https://github.com/SVoxel
(The R8900 is the same as the R9000 except the QoS handling//some "wireless speed model"; For R8900, 2.4G only support 64QAM).
See this thread for more info:
https://www.snbforums.com/threads/third-party-firmware-security.54226/#post-458627
You can also post your questions there or send a private message to Voxel himself:
https://www.snbforums.com/members/voxel.35038/
Hi usually answer in a short time, and has a good support for his users!
- haberdasher_99Apr 23, 2019Aspirant5Ghz broken again. I can’t connect from my TV or my iPhone. 2.4 works fine from iPhone.
- haberdasher_99Apr 23, 2019AspirantTurned off MU-MIMO and Beamforming. 5Ghz working now.
- haberdasher_99Apr 27, 2019Aspirant5Ghz broken yet again. 2.4 is working fine. I will post the content of the logs later but likely nothing of significance will show in there. The radio was transmitting and I can attempt to join it. However, my iPhone it promoted me for my password.
Went to my HP AIO and found I was able to connect to 5Ghz but no internet connection, then connected 2.4Ghz and from the HP it worked fine. Browsed the log. Reconnected from HP to 5Ghz and the Internet works on 5Ghz now for the HP.
Going to test from iPhone next (which is where I am making this post).
