hayhand's avatar
hayhand
Guide
Jul 28, 2015
Move cameras and VCR off main network
 I have 3 wireless cameras connected to my home network that record to a LAN connected VCR.  There is a LOT of traffic from these cameras and cause bandwidth issues when streaming video from the inte...
  • hayhand's avatar
    hayhand
    Aug 02, 2015
    Welll it is time to close out this issue, so here is the answer....
    It actually was a simplistic fix - just keep all the cameras and NVR (network video recorder) all on the same router.  So I used a WMDR3700V2 router set as an AP then one LAN port went back to the modem/router, one port went to the NVR and then the wireless cameras were all attached to that same router.  Now all the traffice stayed on that router yet I could get to all the devices from anywhere on the house LAN.  The problem before was that I had the NVR at the other end of the house on the LAN and so all the camera traffice passed through the modem/router and reduced the BW for other competing devices.  Some times a problem that seems complex and difficult turns out to be easy.  Thanks for all your comments......
    Richard
