hayhand
Jul 28, 2015Guide
Move cameras and VCR off main network
I have 3 wireless cameras connected to my home network that record to a LAN connected VCR. There is a LOT of traffic from these cameras and cause bandwidth issues when streaming video from the inte...
- Aug 02, 2015
Welll it is time to close out this issue, so here is the answer....
It actually was a simplistic fix - just keep all the cameras and NVR (network video recorder) all on the same router. So I used a WMDR3700V2 router set as an AP then one LAN port went back to the modem/router, one port went to the NVR and then the wireless cameras were all attached to that same router. Now all the traffice stayed on that router yet I could get to all the devices from anywhere on the house LAN. The problem before was that I had the NVR at the other end of the house on the LAN and so all the camera traffice passed through the modem/router and reduced the BW for other competing devices. Some times a problem that seems complex and difficult turns out to be easy. Thanks for all your comments......
Richard
Babylon5
Jul 29, 2015NETGEAR Employee Retired
I suggest that you do some research into Ethernet Switches, the routers' LAN ports are an Ethernet switch. See how these can be used to separate traffic flow over a LAN and then I think you will find that the solution is actually quite simple, especially since your cameras are wireless.
This might help;
https://en.wikipedia.org/wiki/Network_switch
“Microsegmentation
Segmentation involes the use of a bridge or a switch (or a router) to split a larger collision domain into smaller ones in order to reduce collision probability, and to improve overall network throughput. In the extreme case (i.e. microsegmentation), each device is located on a dedicated switch port. In contrast to an Ethernet hub, there is a separate collision domain on each of the switch ports. This allows computers to have dedicated bandwidth on point-to-point connections to the network and also to run in full-duplex without collisions. Full-duplex mode has only one transmitter and one receiver per "collision domain", making collisions impossible.”
hayhand
Aug 02, 2015Guide
Richard
