mrfang
Dec 09, 2022Aspirant
Moved, nighthawk r7000 still giving old speeds from previous address
Firmware Version V1.0.11.126_10.2.112 Netgear nighthawk r7000 At my old address I had Optimum getting 200Mbps down/35 up. My new address I have FiOS and I pay for 300/300. I use the same router...
mrfang
Dec 12, 2022Aspirant
There is no modem, it's literally wall -> router -> pc. Firmware is in OP. Tried several factory resets along with power cycles, the setup wizard never gets to finish running for some reason.
Dec 12, 2022Guru - Experienced User
Try a factory reset and setup from scratch with out the router being connected to the wall out let.
If the router worked at or last place and doesn't at this new place, possible issue between the router and the wall outlet and it's service line.
Please give feedback to the other questions presented.
