sigfridov
Dec 01, 2021Follower
Moving Bitdefender License from R8000 in AP mode to LAX20 as Router mode, is it possible?
Friends, I have at home a R9000 as Router and R8000 as AP, so unfortunatelly R9000 device is not able tu support Armor, but I bougth ARMOR feature for R8000 device, which already loaded the code to activate ARMOR meanwhile it was in ROUTER mode, so as soon I moved it to the original configuration which usually I use for it, it means AP mode, the ARMOR feature disapeared.
The question is: Is it possible to move Armor license unuseful in AP mode on my R8000 to a new device LAX20 - Nighthawk 4 Stream LTE WiFi 6 Router which I´ll use in my rest home?
Thanks in advance.
1 Reply
sigfridov wrote:
Fri
The question is: Is it possible to move Armor license unuseful in AP mode on my R8000 to a new device LAX20 - Nighthawk 4 Stream LTE WiFi 6 Router which I´ll use in my rest home?Sounds like a question best thrown at the people who keep their eyes on Armor.
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
Solved: Re: Moving Armor Subscription - NETGEAR Communities
