mdaimm's avatar
mdaimm
Moving from C6300 to X10
Quick question I just bought a x10 to replace my c6300. Can I turn off the wifi on the c6300 and connect the x10 into the c6300? Or should I buy a modem? If i have to buy a modem what would be the bes...
  • mdaimm's avatar
    mdaimm
    Oct 03, 2021
    Got it thank you!
