mdaimm
Oct 03, 2021Aspirant
Moving from C6300 to X10
Quick question I just bought a x10 to replace my c6300. Can I turn off the wifi on the c6300 and connect the x10 into the c6300? Or should I buy a modem? If i have to buy a modem what would be the bes...
- Oct 03, 2021Got it thank you!
Oct 03, 2021Guru - Experienced User
You'll need to look at the user manual for your modem and find the setting that sets the modem to modem only mode or turns OFF router mode.
https://www.netgear.com/support/product/C6300.aspx#docs
Once this is done, then connect the r9000 router to the modem and install it using it's installation guide or user manual.
