GoWest
Apr 16, 2021Aspirant
Moving to a new home with my Nighthawk purchased a few months ago
Hello Community, I will be moving soon to a new home, taking my Nighthawk C7000v2 with me. I purchased it last December. Are there any special disconnect - reconnect procedures I should follow to ...
Apr 16, 2021Guru - Experienced User
are you changing ISP's?
You'd want to make sure its compatible with your isp
- GoWestApr 16, 2021AspirantYes, I will. It is supposed to be compatible
- plemansApr 16, 2021Guru - Experienced User
then it *should* work.
I say should because I've seen an ISP provision a router with a firmware that caused it so others couldn't provision it. I haven't seen it in a while though.
- GoWestApr 16, 2021AspirantI purchased it at Costco I think, not through an ISP. So no ISP had a chance to install any restrictive code.
But the larger question is are there any special disconnect/reconnect procedures to follow?
Or does one simply just unplug the router, move it to the new home, and start over as though the router is brand new right out of the box?
Thanks!
