bryandollery
Oct 21, 2021Follower
MR60 Bricked
I have the Nighthawk MR60 wifi 6 router with one router and 2 satelites. I was updating my router's firmware via the mobile app and the app told me that the firmware couldn't be verified. I tried aga...
Oct 21, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Try nmrpflash?
I've had luck with that when tftp didn't work
https://github.com/jclehner/nmrpflash
Thank you.
