honeylemon
Aug 10, 2021Follower
MR60 (router) / CM1100 (modem) combination - Night Hawk Router Failing?
Hi folks, I have a combination of CM1100 (modem) and MR60 Night Hawk Mesh system as a router. After a year, I am starting to have intermittent internet issues. At first, it was actually wiring is...
Aug 10, 2021Guru - Experienced User
You're still having line issues.
You have a lot of errors on some channels and the power is out of spec.
It should be within 3.5dbmv of each other. your out of that.
Your logs would also help.
If you have any splitters, amplifiers, or signal attenuators, remove them.
I'd move the modem to right where the coax enters the home to prevent wiring in the home from being the issue.
