Whaleless
Jan 01, 2022Follower
MS60 satellite Ethernet port
Hello, I recently purchased the Nighthawk Mesh WiFi 6 System ( MR60 router and MS60 satellites ). From my understanding I’m able to connect my computer to the Ethernet port on the back of a MS60 satel...
michaelkenward
Jan 02, 2022Guru - Experienced User
Whaleless wrote:
From my understanding I’m able to connect my computer to the Ethernet port on the back of a MS60 satellite and be connected? It’s currently not working.
The manual suggests that this should work.
What does "not working" mean?
You get some sort of error message?
What is this computer? Windows? Mac? Something else?
If Windows 10, what happens when you try this?
Fix network connection issues in Windows 10
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- plemansJan 02, 2022Guru - Experienced User
like michaelkenward says, you should be able to use that port to connect devices.
I've even seen users connect a switch to it so they can connect more devices.
Have you tried a different ethernet cable?
Or a different device?
