LawshrinkMD
Jan 22, 2017Aspirant
Much slower LAN speed than direct from the house network
I am now connected to gigabit service, with the google fiber router feeding service into the house Cat5e wiring. I noticed my computer speed tested at 940 or so up and down direct into the wall, but...
- Mar 04, 2017
Everything is working fine now, I got rid of my Google Fiber Network box, and replaced it with a Netgear Pro Smart Switch which can do the vlan2 tagging. Anyway, the router is working fine, passing 900+ through the wired ports.
LawshrinkMD
Jan 23, 2017Aspirant
Hmm, I tried that and no luck, still only reading in the 300-400 MPS. I then changed the router to be an access point, still no luck. Any other ideas?
TheEther
Jan 23, 2017Guru
I forgot to mention that PPPoE will also drag down performance.
Have you enabled any other features on the router? ReadyShare?
- LawshrinkMDJan 26, 2017Aspirant
No, I have done a full reset several times, regular factory settings as both a router (double NAT) as well as an Access Point, and it is still losing 400 mps compared to the straight feed. I would consider upgrading to a better router to avoid this, would an X6 still have this problem?
- StephenBJan 27, 2017Guru - Experienced User
You should be getting around 900 mbits of wan->lan throughput (wired) with this router.
Did you try using different cabling?
- LawshrinkMDMar 04, 2017Aspirant
