LawshrinkMD's avatar
LawshrinkMD
Much slower LAN speed than direct from the house network
I am now connected to gigabit service, with the google fiber router feeding service into the house Cat5e wiring.  I noticed my computer speed tested at 940 or so up and down direct into the wall, but...
  • LawshrinkMD's avatar
    LawshrinkMD
    Mar 04, 2017
    Everything is working fine now, I got rid of my Google Fiber Network box, and replaced it with a Netgear Pro Smart Switch which can do the vlan2 tagging.  Anyway, the router is working fine, passing 900+ through the wired ports.
