AltonL
Jun 08, 2017Aspirant
Multiple DOT4 Ports and printer doesn't work
I have a Netgear R6900. I am trying to connect to a LaserJet 1300 through the Netgear router, using ReadySHARE Printing. I downloaded and installed the ReadySharePrinter_setup_v1.36. Unfortun...
- Jun 08, 2017
I forgot, you need to select one of the other ports first then apply, Select any of the available ports, like LPT or FILE. Apply the change. Close the window, then go back in and highlight on the DOT4 port then select delete.
AltonL
Thanks for your reply. I actually did delete the printer, but that didn't take the DOT4 ports away. When I open up the properties, i can select the DOT4 port and click on Delete Port. That brings up a dialog letting me know I'm about to delete the Port and can add it back later if I wish. Sounds good. But when I click on OK, I get a warning that the requested resource is in use. And it does not delete the port.
I tried looking for DOT4 using REGEDIT, but can't find it. So I'm not sure where this stuff is stored. But whereever it is, it is very secure!
Any other ideas?
Jun 08, 2017Guru - Experienced User
