JCHerrera's avatar
JCHerrera
Multiple USB devices
Hi All, simple question, can you have multiple USB devices connected on the 2 available USB ports of the C7100v?   I can't get to work the USB storage and USB printer at the same time. is it USB s...
  • JCHerrera's avatar
    JCHerrera
    Jan 06, 2021
    Thank you. that confirms that I should be able to have 2 devices ( a printer and storage)
    My device is not letting me do that.
    I will try again.
    Thanks for the pic, my only shows a printer.
