JCHerrera
Jan 05, 2021Aspirant
Multiple USB devices
Hi All, simple question, can you have multiple USB devices connected on the 2 available USB ports of the C7100v? I can't get to work the USB storage and USB printer at the same time. is it USB s...
- Jan 06, 2021
Thank you. that confirms that I should be able to have 2 devices ( a printer and storage)
My device is not letting me do that.
I will try again.
Thanks for the pic, my only shows a printer.
schumaku
Jan 06, 2021Guru - Experienced User
JCHerrera wrote:Thanks, that's exactly what I'm trying to do.
I want to use 1 USB port for USB storage Device and the other USB for a printer.
as soon as I connect the USB storage the USB printer stops working.
I'm not able to access neither if I have both of them plugged in at the same time.
Can't help much beyond this point. Unless there is such a limitaiton in place on this router model, the USB sharing should be workable along with the connected/mounted/accessed storage device.
Your screenshot added shows the ReadyShare storage basic settings without a USB storage device plugged (or ejected). The radio buttons of the UI (an awful bad design!) should not represent an either/or selection - it's just to see the different settings resp information pages for ReadyShare Printer.
Are you in the first three months of the C7100V ownership and could open a free support case?
JCHerrera
Jan 06, 2021Aspirant
I will try again.
