Ayhamb99
Feb 24, 2018Follower
My computer used to find my 2.4 GHZ network easily. Now it can't find it
Basically, My laptop can't find the network that I set up with the R8500 anymore. But it's finding networks from other routers. My laptop is incompatible with 5 GHZ Networks, But it's not even findi...
- Feb 28, 2018
Hi Ayhamb99,
What are the lights on the router? Is wireless(2.4GHz and 5GHz) LED lit up?What is the firmware version of the router?
Check the "Enable SSID broadcast" is checked under wireless setup.
Try changing channels.
JamesGL
Feb 28, 2018NETGEAR Employee Retired
Hi Ayhamb99,
