cdysthe
Oct 28, 2015Virtuoso
My demo used Nighthawk R7000 places all connected devices in completely wrong geographical location!
Hi, I bought a Nighthawk R7000 from Amazon.com. It was demo used and shipped by a Amazon seller, not Amazon.com themselves. When I got it it turned out it was registered with someone else. Netgea...
- Oct 30, 2015
This is not so much about the location of the public IP address. It's about the router's MAC address. See https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/6200-Uses-old-location/m-p/426980#M2982 for more details.
VE6CGX
Oct 28, 2015Master
Have you factory reset the router and reflashed f/w before setting it up?
- cdystheOct 28, 2015Virtuoso
Hi,
It was factory reset when I got it. It had the deault settings. I also upgraded the firmware to the latest. Maybe I should try to factory reset it myself and restore my settings? Where would those location settings be stored in the router?
I poked around in the forums also and found that I am not the only one with this problem: https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/6200-Uses-old-location/m-p/426980#M2982
- TheEtherOct 28, 2015Guru
See my response in the other thread. Blame smartphones and Wi-Fi positioning.
- Jim769Oct 30, 2015Luminary
This is a simple geo location issue because when you hooked up a new device (R7000) your isp was forced to give you a new public IP address that don't match your actual location this is not uncommon. Not much you can do about it as its not something your isp can fix for you in time it will straighten itself out. In the mean time it's a pain in the butt.
