jwaas
Sep 24, 2022Tutor
My devices have been disconnected.
Early spring my router kicked off my Vizio and my Lennox thermostat— same thing today. Did they roll out another failed upgrade? I cannot connect these devices BUT I can disconnect this cancerous rout...
michaelkenward
Sep 24, 2022Guru - Experienced User
jwaas wrote:
Early spring my router kicked off my Vizio and my Lennox thermostat— same thing today. Did they roll out another failed upgrade? I cannot connect these devices BUT I can disconnect this cancerous router. .
Which Netgear equipment do you own?
What modem/gateway it is connected to?
How do you know that the router "kicked off" your device. (Was that from the wifi?) Maybe they just lost the connection.
